* | Update bug report URL | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
* | rtems: Move rtems_cache_aligned_malloc() | Sebastian Huber | 2014-11-25 | 1 | -1/+0 |
| | | | | | | Make sure also the size is cache aligned since otherwise we may have some overlap with the next allocation block. A cache invalidate on this area would be fatal. | ||||
* | mcf5206 libcpu and mcf5206elite: Fix warnings | Joel Sherrill | 2014-10-19 | 4 | -801/+705 |
* | mcf5282: Move cache to libcpu and update av5282 and uC5282 BSPs | Joel Sherrill | 2014-10-16 | 3 | -0/+133 |
* | libcpu/m68k/mcf532x/cache/cachepd.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -1/+3 |
* | libcpu/m68k/mcf5235/cache/cachepd.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -0/+1 |
* | libcpu/m68k/mcf5223x/cache/cachepd.c: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -0/+1 |
* | Move CPU cache support from mcf5225x BSP to libcpu | Joel Sherrill | 2014-10-16 | 2 | -6/+46 |
* | libcpu/m68k/mcf5272/clock/ckinit.c: Fix warnings | Joel Sherrill | 2014-10-13 | 1 | -124/+68 |
* | libcpu/m68k/mcf5206/clock/ckinit.c: Fix warnings | Joel Sherrill | 2014-10-13 | 1 | -108/+48 |
* | Eliminate use of /*PAGE and clean up formatting | Joel Sherrill | 2014-10-09 | 1 | -17/+10 |
* | bsps/mcf5235: Fix warnings | Sebastian Huber | 2014-10-09 | 1 | -810/+812 |
* | bsps/mcf548x: Fix warnings | Sebastian Huber | 2014-10-09 | 1 | -0/+1 |
* | bsps/mcf548x: Fix warnings | Sebastian Huber | 2014-10-09 | 1 | -1099/+1101 |
* | bsps/mcf548x: Fix warnings | Sebastian Huber | 2014-10-09 | 1 | -1/+2 |
* | Use correct prototype of benchmark_timer_read() | Joel Sherrill | 2014-09-16 | 4 | -18/+28 |
| | | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output. | ||||
* | m68k/shared/misc/memProbe.c: Add prototype to eliminate warning | Joel Sherrill | 2014-06-01 | 1 | -0/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 18 | -18/+18 |
* | termios: Update due to API changes | Sebastian Huber | 2013-06-25 | 1 | -11/+12 |
| | | | | | Termios notifies now the driver about an inactive transmit with the length argument set to zero. | ||||
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -640/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-07-19 | 3 | -6/+0 |
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 1 | -1/+1 |
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 1 | -2/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 51 | -66/+0 |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 |
* | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 2012-05-03 | 5 | -49/+35 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 8 | -8/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -3/+3 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -8/+0 |
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 6 | -28/+34 |
| | | | | | | * mcf5225x/network/fec.c, mcf5235/cache/cachepd.c, mcf532x/cache/cachepd.c, shared/cache/cache.c, shared/misc/m68kidle.c: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-04-05 Thomas Znidar <t.znidar@embed-it.com> | Joel Sherrill | 2010-04-05 | 7 | -1/+3899 |
| | | | | | | * Makefile.am, configure.ac, preinstall.am: Add mcf5225x support. * mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h, mcf5225x/network/fec.c: New files. | ||||
* | Fix hex constants. | Eric Norum | 2010-03-16 | 2 | -2/+6 |
* | adapted to new prototype for *_write function | Thomas Doerfler | 2009-12-17 | 3 | -10/+17 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-08 | 2 | -35/+35 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 41 | -591/+591 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 4 | -84/+84 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 16 | -75/+75 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 2 | -2/+2 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | 2009/10/20 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-20 | 1 | -1/+1 |
| | | | | * shared/misc/m68kidle.c: somehow this change was never committed, sorry. | ||||
* | add MC_DMA support to MCF548x | Thomas Doerfler | 2009-10-15 | 12 | -0/+4408 |
* | * mcf5282/include/mcf5282.h: add missing (x) params to four macros, added ↵ | Thomas Doerfler | 2009-10-08 | 2 | -70/+75 |
| | | | | paranthesis around usage of x in some macros | ||||
* | *** empty log message *** | Till Straumann | 2009-09-10 | 1 | -0/+1 |
* | 2009-09-10 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-09-10 | 1 | -0/+5 |
| | | | | | * shared/misc/m68kidle.c: added "cc" clobber to inline asm; STOP instruction modifies CCR! | ||||
* | add cache definition for mcfv4e | Thomas Doerfler | 2009-07-17 | 2 | -0/+7 |
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -1/+6 |
| | | | | | * shared/misc/m68kidle.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-11 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2009-02-11 | 3 | -3/+22 |
| | | | | | | PR 1369/bsps * Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp floating-point emulation. | ||||
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 2 | -0/+5 |
| | | | | * mcf5206/timer/timerisr.S: Make compile again. |
