* ChangeLog: Merge-in mcf5206/ChangeLog.
* mcf5206/ChangeLog: Remove.
* Makefile.am: Convert to automake compilation rules.
* configure.ac: Remove.
* .cvsignore: Reflect changes above.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* configure.ac: Cosmetics.
* clock/Makefile.am: Remove.
* console/Makefile.am: Remove.
* mbus/Makefile.am: Remove.
* timer/Makefile.am: Remove.
* Makefile.am: Merge-in former clock/Makefile.am, console/Makefile.am,
include/Makefile.am, mbus/Makefile.am, timer/Makefile.am.
* mbus/Makefile.am: Cosmetics.
* Makefile.am: Reformat.
* clock/Makefile.am: Reformat.
* console/Makefile.am: Reformat.
* include/Makefile.am: Reformat. Use dirstamps for preinstallation.
* timer/Makefile.am: Reformat.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* clock/ckinit.c, console/mcfuart.c, include/mcf5206e.h,
include/mcfmbus.h, include/mcfuart.h, mbus/mcfmbus.c, timer/timer.c,
timer/timerisr.S: URL for license changed.
* clock/ckinit.c, console/mcfuart.c, timer/timer.c, timer/timerisr.S:
Correct copyright statements.
m68040/Makefile.am: Reflect having moved automake.
m68040/fpsp/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/misc/Makefile.am: Reflect having moved automake.
* clock/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* console/Makefile.am: Likewise.
* mbus/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* mbus/mcfmbus.c: Per PR323, move the mbus_send command on line 232
to after the state has been set.
* configure.ac: Add RTEMS_PROG_CCAS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* mbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/Makefile.am: Fix TMPINSTALL_FILES to make automake-1.5
happy.
* .cvsignore: Add more entries.
* New libcpu support for mcf5206e.
* ChangeLog, clock/ckinit.c, clock/.cvsignore, configure.ac,
console/mcfuart.c, console/.cvsignore, include/mcf5206e.h,
include/mcfmbus.h, include/mcfuart.h, include/.cvsignore,
mbus/mcfmbus.c, mbus/.cvsignore, timer/timer.c, timer/timerisr.S,
timer/.cvsignore, .cvsignore: New files.
