enclose.
were a number of minor problems which had to be fixed to get it
to compile including modifying the compile rule to handle C++ comments,
changing the syntax of the include statement, and getting rid of "%"
as part of register names.
to RTEMS by Eric Norum. It is freely distributable and was acquired
from the Motorola WWW site. More info is in the FPSP README.
