path: root/c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (unfollow)
2018-03-26bsps/m68k: Move fpsp support to bspsSebastian Huber1-480/+0
This patch is a part of the BSP source reorganization. Update #3285.
2018-03-26bsps/m68k: Use namespace headerSebastian Huber1-0/+1
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-1/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2009-12-04Whitespace removal.Ralf Corsepius1-11/+11
1998-12-14Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename allJoel Sherrill1-0/+0
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake.
1998-01-16Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1-0/+2
> RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
1997-07-09This code was in the tree but not actually being compiled. ThereJoel Sherrill1-1/+1
were a number of minor problems which had to be fixed to get it to compile including modifying the compile rule to handle C++ comments, changing the syntax of the include statement, and getting rid of "%" as part of register names.
1997-04-16Added the MC68040 Floating Point Support Package. This was portedJoel Sherrill1-0/+478
to RTEMS by Eric Norum. It is freely distributable and was acquired from the Motorola WWW site. More info is in the FPSP README.
