* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -1/+0 |
* | Whitespace removal. | Ralf Corsepius | 2009-12-04 | 1 | -44/+44 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 1 | -0/+651 |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. |
