Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* Makefile.am, configure.ac, preinstall.am: Add mcf5225x support.
* mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h,
mcf5225x/network/fec.c: New files.
PR 1369/bsps
* Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp
floating-point emulation.
* Makefile.am, configure.ac, preinstall.am: Adding mcf5329 BSP and CPU
support.
* mcf532x/include/mcf532x.h: New file.
* mcf52235/include/mcf52235.h: Removed. Moved to the more generic
mcf5223x.h.
* mcf5223x/include/mcf5223x.h: New. Was mcf52235.h.
* Makefile.am, configure.ac, preinstall.am: Changed from mcf52235
to mcf5223x.
* mcf52235/include/mcf52235.h: New.
* preinstall.am, configure.ac, Makefile.am: Add 52235 support.
* configure.ac: Use RTEMS_AMPOLISH3.
* ChangeLog, Makefile.am, configure.ac, preinstall.am: Addition of
mcf5235 support.
* mcf5235/include/mcf5235.h: New file.
Add AMPOLISH3.
* configure.ac: Remove RTEMS_ENABLE_BARE.
* Makefile.am, configure.ac: Added CSB360 BSP
* mcf5272/.cvsignore, mcf5272/ChangeLog, mcf5272/Makefile.am,
mcf5272/clock/.cvsignore, mcf5272/clock/ckinit.c,
mcf5272/include/.cvsignore, mcf5272/include/mcf5272.h,
mcf5272/timer/.cvsignore, mcf5272/timer/timer.c,
mcf5272/timer/timerisr.S: New files.
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP.
* m68040/Makefile.am: Merge-in m68040/fpsp/Makefile.am.
Use automake-compilation rules.
* m68040/fpsp/Makefile.am: Remove.
* shared/Makefile.am: Use automake compilation rules.
* Makefile.am: Reflect changes above. Remove CPU_SUBDIR.
* configure.ac: Require automake >= 1.8.2.
Add subdir-objects to AUTOMAKE_OPTIONS.
Remove CHECK_CUSTOM_BSP.
* shared/cache/Makefile.am: Remove.
* shared/misc/Makefile.am: Remove.
* shared/Makefile.am: Merge-in the Makefile.ams above.
Eliminate VPATH.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* configure.ac: Add RTEMS_PROG_CCAS.
* configure.ac, shared/misc/Makefile.am: PR217 required that the
idle task be moved to libcpu so it could be more acutely aware of
the CPU model. This file was modified to pick up the idle task
from there.
* shared/misc/m68kidle.c: New file.
* configure.ac: Be more specific about looking at CPU32 and CPU32+
CPU model names so we can turn on the best compile of memcpy.c.
* configure.ac: Replace mcpu32 by mcpu32p conditional.
* share/misc/Makefile.am: Fix AM_CPPFLAGS bug.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* shared/misc/memcpy.c: Moved from score/cpu/m68k.
* configure.ac, shared/Makefile.am: Modified to reflect new directory.
* shared/misc/.cvsignore, shared/misc/Makefile.am: New file.
* m68040/fpsp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* m68040/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am, configure.ac: New libcpu support for mcf5206e.
* configure.in: Remove.
