* mcf5225x/network/fec.c, mcf5235/cache/cachepd.c,
mcf532x/cache/cachepd.c, shared/cache/cache.c, shared/misc/m68kidle.c:
* Makefile.am, configure.ac, preinstall.am: Add mcf5225x support.
* mcf5225x/include/fec.h, mcf5225x/include/mcf5225x.h,
mcf5225x/network/fec.c: New files.
paranthesis around usage of x in some macros
* shared/misc/m68kidle.c: added "cc" clobber to inline
asm; STOP instruction modifies CCR!
* shared/misc/m68kidle.c: Change prototype of IDLE thread to
consistently return void * and take a uintptr_t argument.
PR 1369/bsps
* Makefile.am, configure.ac: Fix name clashes when using MC68040 fpsp
floating-point emulation.
* mcf5206/timer/timerisr.S: Make compile again.
* Makefile.am: Split out various BSPs bspstart.c contents. Move cache
management code here.
* mcf5223x/cache/cachepd.c, mcf5235/cache/cachepd.c: New files.
* mcf5206/timer/timerisr.S: Remove unnecessary include of bsp.h
* mcf548x/include/Freescale_license.txt: Convert to UNIX CR/LF style,
eliminate characters with 8th bit set.
* mcf548x/include/mcf548x.h: Convert to Unix file format.
* mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: The Shared Memory
Driver no longer requires the special IOCTL in Clock_control. This
was a hack which has existed since before the Classic API Timer
Manager was implemented. All implementations of and references to
Clock_control were removed.
* mcf5206/timer/timer.c, mcf5272/timer/timer.c: Convert to "bool".
* mcf5206/console/mcfuart.c, mcf5206/include/mcfuart.h:
Eliminate rtems_boolean.
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
methods to follow RTEMS programming conventions.
* m68040/fpsp/rtems_fpsp.c: Move extern outside of braces.
* shared/misc/m68kidle.c: Correct prototype of Idle threads.
* Makefile.am, mcf532x/include/mcf532x.h, shared/cache/cache_.h: Add
cache support for 5329. Enable the cache in copyback and
write-through so we can assume that in BSP.
* mcf532x/cache/cachepd.c: New file.
* Makefile.am, configure.ac, preinstall.am: Adding mcf5329 BSP and CPU
support.
* mcf532x/include/mcf532x.h: New file.
* mcf52235/include/mcf52235.h: Removed. Moved to the more generic
mcf5223x.h.
* mcf5223x/include/mcf5223x.h: New. Was mcf52235.h.
* Makefile.am, configure.ac, preinstall.am: Changed from mcf52235
to mcf5223x.
* mcf52235/include/mcf52235.h: New.
* preinstall.am, configure.ac, Makefile.am: Add 52235 support.
* mcf5206/clock/ckinit.c, mcf5272/clock/ckinit.c: Eliminate copies of
the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* m68k/mcf5235/include/mcf5235.h: Remove '/' from define label.
* Makefile.am: Now use the m68k memcpy and memset recently added to
newlib instead of our own.
* shared/misc/memcpy.c: Removed.
* mcf5272/clock/ckinit.c, mcf5272/include/mcf5272.h,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
attribute to low-level scalar type definitions and
removed intermediate (void*) cast.
* m68k/mcf5282/include/mcf5282.h: fixed wrong value
of MCF5282_QSPI_QDLYR_SPE.
* configure.ac: Use RTEMS_AMPOLISH3.
* Makefile.am: Fix broken patch to mcf5235.
* Makefile.am: Eliminate duplicate entry for include_mcf5235... .
* ChangeLog, Makefile.am, configure.ac, preinstall.am: Addition of
mcf5235 support.
* mcf5235/include/mcf5235.h: New file.
* Makefile.am: Merge-in mcf5282/Makefile.am.
* preinstall.am: Regenerate.
* mcf5282/Makefile.am: Remove.
* configure.ac: Remove mcf5282/Makefile.
* Makefile.am: Merge-in mcf5272/Makefile.am.
* mcf5272/Makefile.am: Remove.
* configure.ac: Remove mcf5272/Makefile.
* Makefile.am: Merge-in mcf5206/Makefile.am.
* mcf5206/Makefile.am: Remove.
* configure.ac: Remove mcf5206/Makefile.
* Makefile.am: Merge-in m68040/Makefile.am.
* m68040/Makefile.am: Remove.
* configure.ac: Remove m68040/Makefile.
* Makefile.am: Merge-in shared/Makefile.am.
* preinstall.am: New.
* shared/Makefile.am: Remove.
* configure.ac: Remove shared/Makefile.
Add AMPOLISH3.
* mcf5282/include/Makefile.am: Remove (unused).
* mcf5206/include/mcfuart.h: Reformatted.
