* Makefile.am: Fix typo in path.
PR 1537/libcpu
* shared/cache/cache.c: Removed.
* .cvsignore: New file.
* ChangeLog, Makefile.am, configure.ac, preinstall.am,
shared/cache/cache.c, shared/cache/cache_.h, shared/misc/memcpy.c: New files.
