* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am: Don't
include .../lib.am.
Use automake compilation rules.
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake >= 1.8.2.
* i960ca/Makefile.am: Remove all-local: $(ARCH).
* i960ka/Makefile.am: Remove all-local: $(ARCH).
* i960rp/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamps for preinstallation.
* i960ca/Makefile.am: Reformat.
* i960ka/Makefile.am: Reformat.
* i960rp/Makefile.am: Reformat.
i960ca/Makefile.am: Reflect having moved automake.
i960ka/Makefile.am: Reflect having moved automake.
i960rp/Makefile.am: Reflect having moved automake.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* i960ca/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960ka/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960rp/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960ca/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960ka/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960rp/Makefile.am: Remove AUTOMAKE_OPTIONS.
Remove H_FILES.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
Include compile.am
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
