* include/Makefile.am: Removed.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* shared/soft_reset_asm.S: Removed.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* i960ca/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960ka/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960rp/Makefile.am: Use .$(OBJEXT) instead of .o.
* include/i960CA.h, include/i960RP.h: Correct inline assembly
forward reference labels.
* i960ca/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960ka/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960rp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
Remove H_FILES.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* Makefile.am: Corrected condition CPU model selection so
multilib'ing and bare BSP works.
Include compile.am
