Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
This is a cache manager implementation header file.
Update #3254.
Fixes #2515.
Make sure also the size is cache aligned since otherwise we may have
some overlap with the next allocation block. A cache invalidate on this
area would be fatal.
* page.c: Remove unused var "dirCount".
* cpu.h: Remove warnings.
* cache.c, cpu.h, cpuModel.h:
* page.c: Remove CVS-Header tag. Add CVS-Id
* byteorder.h, cpu.h, page.c: Fix typo where license said
found in found in.
* byteorder.h: added ld_le16, st_le16.
* cache.c, page.c: Use masks and shift operations instead of
bit-fields.
* cpuModel.S, cpuModel.h, displayCpu.c: Update to include more reserved
bits and pick out a bit more information.
* page.c: Use bsp_mem_size.
* displayCpu.c: Fixed formatting for prettier printing;
don't print more than 8 flags on a single line of output.
* cpuModel.S, cpuModel.h, displayCpu.c: Save/cache CPUID:ECX
(extended capabilities) in a new variable (x86_capability_x).
Added more known flag description strings (printCpuInfo())
and let 'printCpuInfo()' dump the extended feature flags, too.
* page.c: Fixed warnings.
Michael South <msouth@msouth.org>
PR 1344/bsps
* cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very
slow on some systems. TSC use is auto-detected by default.
* cache.c, displayCpu.c, page.c: Add missing prototypes.
* page.c: Redo print to not have cvs conflict marker.
* configure.ac: Use RTEMS_AMPOLISH3.
