You will find enclosed a patch which contains, for Intel PC386 target :
- an Ethernet driver for DEC21140 device based boards.
- a simple cache management with paging mechanism.
1. Finally fixes raw interrupts for pc386
2. Makes some minor cleanup in console and startup
3. Makes rtems_termios_dequeue_characters() to return count of
outstanding chars - it allows to simplify console isrs a little
bit.
4. pc386 uart modified to be friendlier to termios parameter changes,
to have minor performance improvement and to take advantage of
of above termios modification.
patches missing from 980911.
Here is a patch that enables to catch exception
and get message before crashing RTEMS :)
It should be generic to any Intel port although enabled
only for pc386 BSP...
[Joel] I fixed the bug I introduced in irq_asm.s...
inline with the new IRQ structure.
Enabled on the pc386.
of theses targets...
