* | Add missing prototypes. | Ralf Corsepius | 2008-08-16 | 3 | -6/+6 |
* | 2008-08-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-16 | 1 | -0/+4 |
| | | | | * cache.c, displayCpu.c, page.c: Add missing prototypes. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2007-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-28 | 2 | -1/+5 |
| | | | | * page.c: Redo print to not have cvs conflict marker. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-05-16 | 2 | -3/+5 |
| | | | | * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+2 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -2/+2 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 1 | -0/+2 |
| | | | | | * Makefile.am: Add preinstall.am * preinstall.am: New. | ||||
* | Add preinstall.am | Ralf Corsepius | 2005-11-04 | 1 | -23/+6 |
* | New | Ralf Corsepius | 2005-11-04 | 1 | -0/+34 |
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 2 | -0/+5 |
| | | | | * configure.ac: Add AMPOLISH3. | ||||
* | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-04 | 1 | -0/+4 |
| | | | | * byteorder.h: New. | ||||
* | New. | Ralf Corsepius | 2005-11-04 | 1 | -0/+22 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -3/+7 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-03 | 2 | -1/+5 |
| | | | | * Makefile.am: Fix typo. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 2 | -33/+8 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-19 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_ENABLE_BARE. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -3/+0 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -2/+7 |
| | | | | | * cpuModel.S: Include <rtems/asm.h> instead of <asm.h>. * idtr.S: Include <rtems/asm.h> instead of <asm.h>. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 2 | -1/+5 |
| | | | | * page.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-26 | 2 | -1/+5 |
| | | | | * configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include .../lib.am. | ||||
* | 2004-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-21 | 2 | -288/+5 |
| | | | | | PR 557/bsps * cpu.c: Removed. File appears to have been orphaned around June 2000 | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 5 | -27/+59 |
| | | | | | | | | | * Makefile.am: Split the blob of *.o into cache.rel, page.rel and score.rel. Add PREINSTALL_DIRS. Use automake compilation rules. * page.c, cpuModel.S: Remove stray blanks. * configure.ac: Require automake >= 1.8.2. Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-16 | 2 | -12/+16 |
| | | | | * Makefile.am: Eliminate VPATH. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -10/+25 |
| | | | | * Makefile.am: Reformat. Use dirstamps for preinstallation. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 8 | -7/+12 |
| | | | | | * cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 2 | -3/+7 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-19 | 3 | -7/+8 |
| | | | | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-01 | 2 | -0/+5 |
| | | | | * configure.ac: Add RTEMS_PROG_CCAS. |
