* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | Patch from John Cotton <john.cotton@nrc.ca> to correct cache | Joel Sherrill | 2000-06-14 | 1 | -2/+2 |
| | | | | | | routine naming to follow RTEMS package/object.method rule. This patch also eliminated calls to the obsolete routine m68k_enable_caching. | ||||
* | Prototypes for cache manager support functions now agree. | Joel Sherrill | 2000-06-13 | 1 | -1/+1 |
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 1 | -0/+16 |
now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. |
