* cache.c: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* cpu.h: Ditto. Remove parts moved to score/cpu/i386.
* registers.h: Add BIG-FAT warning.
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
