2013-03-08 | RTEMS: Delete ChangeLog files. | Gedare Bloom | 1 | -315/+0 | |
This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | |||||
2011-10-23 | 2011-10-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* page.c: Remove unused var "dirCount". | |||||
2011-03-14 | 2011-03-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* cpu.h: Remove warnings. | |||||
2011-02-11 | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* cache.c, cpu.h, cpuModel.h: Use "__asm__" instead of "asm" for improved c99-compliance. | |||||
2011-02-02 | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require autoconf-2.68, automake-1.11.1. | |||||
2011-01-29 | 2011-01-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* page.c: Remove CVS-Header tag. Add CVS-Id | |||||
2011-01-28 | 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* byteorder.h, cpu.h, page.c: Fix typo where license said found in found in. | |||||
2010-07-06 | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -0/+4 | |
* byteorder.h: added ld_le16, st_le16. | |||||
2010-05-21 | 2010-05-21 Vinu Rajashekhar <vinutheraj@gmail.com> | Joel Sherrill | 1 | -0/+5 | |
* cache.c, page.c: Use masks and shift operations instead of bit-fields. | |||||
2010-04-15 | 2010-04-15 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* cpuModel.S, cpuModel.h, displayCpu.c: Update to include more reserved bits and pick out a bit more information. | |||||
2009-12-11 | 2009-12-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* page.c: Use bsp_mem_size. | |||||
2009-10-29 | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -0/+5 | |
* displayCpu.c: Fixed formatting for prettier printing; don't print more than 8 flags on a single line of output. | |||||
2009-10-28 | 2009-10-28 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -0/+7 | |
* cpuModel.S, cpuModel.h, displayCpu.c: Save/cache CPUID:ECX (extended capabilities) in a new variable (x86_capability_x). Added more known flag description strings (printCpuInfo()) and let 'printCpuInfo()' dump the extended feature flags, too. | |||||
2009-05-06 | 2009-05-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* page.c: Fixed warnings. | |||||
2008-12-03 | 2008-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -0/+7 | |
Michael South <msouth@msouth.org> PR 1344/bsps * cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very slow on some systems. TSC use is auto-detected by default. | |||||
2008-08-16 | 2008-08-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* cache.c, displayCpu.c, page.c: Add missing prototypes. | |||||
2007-03-28 | 2007-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* page.c: Redo print to not have cvs conflict marker. | |||||
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-05-16 | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use RTEMS_AMPOLISH3. | |||||
2005-11-04 | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+2 | |
* Makefile.am: Add preinstall.am * preinstall.am: New. | |||||
2005-11-04 | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+1 | |
* configure.ac: Add AMPOLISH3. | |||||
2005-11-04 | 2005-11-04 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* byteorder.h: New. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-03 | 2005-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Fix typo. | |||||
2005-01-02 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Remove build-variant support. | |||||
2004-10-19 | 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_ENABLE_BARE. | |||||
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* cpuModel.S: Include <rtems/asm.h> instead of <asm.h>. * idtr.S: Include <rtems/asm.h> instead of <asm.h>. | |||||
2004-03-31 | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* page.c: Convert to using c99 fixed size types. | |||||
2004-03-26 | 2004-03-26 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP. | |||||
2004-02-06 | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Don't include .../lib.am. | |||||
2004-01-21 | 2004-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
PR 557/bsps * cpu.c: Removed. File appears to have been orphaned around June 2000 | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+9 | |
* Makefile.am: Split the blob of *.o into cache.rel, page.rel and score.rel. Add PREINSTALL_DIRS. Use automake compilation rules. * page.c, cpuModel.S: Remove stray blanks. * configure.ac: Require automake >= 1.8.2. Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||||
2003-12-16 | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Eliminate VPATH. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | |||||
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-02 | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Remove all-local: $(ARCH). | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reformat. Use dirstamps for preinstallation. | |||||
2003-10-22 | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
2003-10-21 | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_CHECK_CPU. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c: URL for license changed. | |||||
2003-08-18 | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Reflect having moved aclocal/. | |||||
2003-08-18 | Fix broken ChangeLog entries. | Ralf Corsepius | 1 | -1/+1 | |
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
Makefile.am: Reflect having moved automake. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2003-02-11 | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | |||||
* configure.ac: AC_PREREQ(2.57). |
