* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: Add RTEMS_PROG_CCAS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuModel.S: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* registers.h: Removed.
* Makefile.am: Remove registers.h.
* cache.c: Include <rtems/score/registers.h> instead of
* cpu.h: Ditto. Remove parts moved to score/cpu/i386.
* registers.h: Add BIG-FAT warning.
* cpuModel.h: PR 146.
Adding guards. Remove unnecessary headers.
* i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h.
* i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.in: Remove.
* Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Apply include_*HEADERS instead of H_FILES.
* .cvsignore: Add cache.h.
* displayCpu.c: Added include of <rtems.h> to eliminate warnings.
* page.c: Readd deleted comment lines.
* page.c: Replaced prototype of printk() with include of <bspIo.h>.
* idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so
i386 RTEMS can be multilib'ed.
* Makefile.am: Include compile.am
