* clock/clock.c, include/semaphore.h, semaphore/semaphore.c,
timer/timer.c: URL for license changed.
milli/Makefile.am: Reflect having moved automake.
semaphore/Makefile.am: Reflect having moved automake.
* configure.ac: RTEMS_CHECK_CUSTOM_BSP.
* milli/Makefile.am: Ditto.
* semaphore/Makefile.am: Ditto.
* timer/Makefile.am: Ditto.
* milli/Makefile.am: Use .$(OBJEXT) instead of .o.
* semaphore/Makefile.am: Use .$(OBJEXT) instead of .o.
* milli/Makefile.am: Remove AUTOMAKE_OPTIONS.
* semaphore/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/Makefile.am, milli/Makefile.am, semaphore/Makefile.am,
timer/Makefile.am: Include compile.am
converted to automake.
which does the following:
patches
NOTES:
inside of those Makefiles.
directories.
to this at the moment.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
in the include directory.
BSP needs to be eliminated.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
