* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 19 | -19/+19 |
* | Remove stray blanks. | Ralf Corsépius | 2012-10-19 | 19 | -19/+0 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 19 | -38/+0 |
* | 2011-04-20 Rohan Kangralkar <rkangral@ece.neu.edu> | Joel Sherrill | 2011-04-20 | 1 | -1/+7 |
| | | | | | | | | | | | | | | PR 1781/bsps * bf52x/include: Added additional MMR. * bf52x/interrupt: The BF52X processors have a different System interrupt controller than present in the 53X range of processors. The 52X have 8 interrupt assignment registers. The implementation uses tables to increase predictability. * serial/uart.?: Added DMA based and interrupt based transfer support. The uart code used a single ISR for TX and RX and tried to identify and multiplex inside the ISR. In the new code the type of interrupt is identified by the central ISR dispatcher bf52x/interrupt or interrupt/. This simplifies the UART ISR. | ||||
* | 2010-01-11 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2010-01-11 | 1 | -2/+2 |
| | | | | | | | * serial/spi.c, serial/spi.h: Fill in skeleton with functional SPI master code. * include/spiRegs.h: Correct spi shadow register declaration. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-05-25 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2009-05-27 | 1 | -2/+2 |
| | | | | | | | PR 1418/bsps * mmu/mmu.c: enable mmu after initializing it. * mmu/mmu.h: add missing mmu flags entries. * include/mmuRegs.h: correct a couple field name typos. | ||||
* | 2008-09-25 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2008-09-25 | 3 | -1/+10 |
| | | | | * clock/clock.c, include/bf533.h, include/bf537.h, include/sicRegs.h: | ||||
* | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2008-08-15 | 19 | -0/+1886 |
* ChangeLog, Makefile.am, README, configure.ac, preinstall.am, cache/cache.c, cache/cache_.h, clock/clock.c, clock/rtc.c, clock/tod.h, include/bf533.h, include/bf537.h, include/cecRegs.h, include/coreTimerRegs.h, include/dmaRegs.h, include/ebiuRegs.h, include/ethernetRegs.h, include/gpioRegs.h, include/memoryRegs.h, include/mmuRegs.h, include/ppiRegs.h, include/rtcRegs.h, include/sicRegs.h, include/spiRegs.h, include/sportRegs.h, include/timerRegs.h, include/twiRegs.h, include/uartRegs.h, include/wdogRegs.h, interrupt/interrupt.c, interrupt/interrupt.h, mmu/mmu.c, mmu/mmu.h, network/ethernet.c, network/ethernet.h, serial/spi.c, serial/spi.h, serial/sport.c, serial/sport.h, serial/twi.c, serial/twi.h, serial/uart.c, serial/uart.h, timer/timer.c: New files. |
