2018-03-26 | bsp/bfin: Move libcpu content to bsps | Sebastian Huber | 2 | -339/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2016-11-09 | score: Add and use Thread_Control::is_idle | Sebastian Huber | 1 | -5/+1 | |
Update #2797. | |||||
2016-03-27 | libcpu/bfin/clock/clock.c: Fix warning by including <rtems/clockdrv.h> | Joel Sherrill | 1 | -0/+2 | |
2016-01-11 | score: Introduce Thread_Entry_information | Sebastian Huber | 1 | -2/+2 | |
This avoids potential dead code in _Thread_Handler(). It gets rid of the dangerous function pointer casts. Update #2514. | |||||
2015-06-26 | score: Simplify <rtems/system.h> | Sebastian Huber | 1 | -0/+1 | |
Drop the <rtems/score/percpu.h> include since this file exposes a lot of implementation details. | |||||
2015-03-17 | libcpu/bfin/clock/rtc.c: Do not use rtems_clock_get() | Joel Sherrill | 1 | -2/+2 | |
2014-10-31 | libcpu/bfin/clock/tod.h: Delete - missed on previous commits | Joel Sherrill | 1 | -61/+0 | |
2014-10-16 | bfin libcpu and libbsp: Fix warnings | Joel Sherrill | 2 | -2/+3 | |
2014-10-13 | libcpu/bfin/clock: Fix warnings | Joel Sherrill | 2 | -52/+21 | |
2014-09-16 | tod.h -> libcsupport like other driver and helper prototype files | Joel Sherrill | 1 | -1/+1 | |
This rippled into the handful of files that should have been using <rtems/tod.h>. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 3 | -3/+3 | |
2013-08-14 | bsps: Fix clock driver defines | Sebastian Huber | 1 | -2/+2 | |
2013-08-01 | score: Rename tod.h to todimpl.h | Sebastian Huber | 1 | -1/+1 | |
2013-07-26 | score: Merge tod implementation into one file | Sebastian Huber | 1 | -0/+1 | |
Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS(). | |||||
2013-05-31 | score: Remove idle field of Per_CPU_Control | Sebastian Huber | 1 | -2/+5 | |
This field is unused except for special case simulator clock drivers. In these places use an alternative. Add and use _Thread_Set_global_exit_status() and _Thread_Get_global_exit_status(). | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 3 | -6/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-11-30 | Whitespace removal. | Ralf Corsepius | 3 | -20/+20 | |
2009-10-20 | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* clock/rtc.c: Add initializer (Silence warning). | |||||
2009-05-27 | 2009-05-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2 | -27/+103 | |
* clock/rtc.c, clock/tod.h: Update for new RTC driver interface. | |||||
2008-09-25 | 2008-09-25 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 1 | -0/+3 | |
* clock/clock.c, include/bf533.h, include/bf537.h, include/sicRegs.h: | |||||
2008-09-05 | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -43/+0 | |
* clock/clock.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. | |||||
2008-08-18 | Add missing prototypes. | Ralf Corsepius | 1 | -3/+3 | |
2008-08-15 | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 3 | -0/+397 | |
* ChangeLog, Makefile.am, README, configure.ac, preinstall.am, cache/cache.c, cache/cache_.h, clock/clock.c, clock/rtc.c, clock/tod.h, include/bf533.h, include/bf537.h, include/cecRegs.h, include/coreTimerRegs.h, include/dmaRegs.h, include/ebiuRegs.h, include/ethernetRegs.h, include/gpioRegs.h, include/memoryRegs.h, include/mmuRegs.h, include/ppiRegs.h, include/rtcRegs.h, include/sicRegs.h, include/spiRegs.h, include/sportRegs.h, include/timerRegs.h, include/twiRegs.h, include/uartRegs.h, include/wdogRegs.h, interrupt/interrupt.c, interrupt/interrupt.h, mmu/mmu.c, mmu/mmu.h, network/ethernet.c, network/ethernet.h, serial/spi.c, serial/spi.h, serial/sport.c, serial/sport.h, serial/twi.c, serial/twi.h, serial/uart.c, serial/uart.h, timer/timer.c: New files. |
