* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | bsp/arm: Add CP15 methods | Ralf Kirchner | 2014-03-13 | 1 | -1/+98 |
* | bsps/arm: Use Normal memory for code and data | Sebastian Huber | 2014-01-13 | 1 | -3/+7 |
* | bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE | Sebastian Huber | 2013-10-27 | 1 | -5/+9 |
| | | | | | Delete ARMV7_MMU_DATA_READ_WRITE_SHAREABLE and move RTEMS_SMP specific MMU attribute settings to arm-cp15.h. | ||||
* | Add a new necessary definition needed for raspberrypi MMU support | Hesham AL-Matary | 2013-10-03 | 1 | -0/+21 |
| | | | | | | | | | | | The new ARM_CP15_CTRL_XP is necessary to share ARMv6 and ARMv7 page-table formats and definitions. It enables the extended page tables (introduced in ARMv6) to be configured for the hardware page translation mechanism. This way we can share ARMv6 and ARMv7 page tables entry formats. Other Fault Status Register Definitions can be useful for debugging or excpetion handlers. | ||||
* | bsps/arm: Fix ARM CP15 opcode for get functions | Sebastian Huber | 2013-09-05 | 1 | -3/+3 |
* | bsps/arm: Add more CP15 cache functions | Ric Claus | 2013-08-22 | 1 | -0/+65 |
* | bsps/arm: Set vector base address if necessary | Sebastian Huber | 2013-06-20 | 1 | -0/+47 |
* | bsps/arm: Add SMP support | Sebastian Huber | 2013-05-31 | 1 | -0/+57 |
* | bsps/arm: Use Write-Allocate cache for ARMv7 | Sebastian Huber | 2013-05-31 | 1 | -2/+2 |
* | bsps/arm: Merge ARMv7 MMU section definitions | Sebastian Huber | 2013-05-31 | 1 | -0/+43 |
* | bsps/arm: Remove superfluous parameter | Sebastian Huber | 2013-05-06 | 1 | -2/+1 |
* | bsps/arm: Support ARMv7 VMSA sections and control | Sebastian Huber | 2013-05-03 | 1 | -4/+29 |
* | bsps/arm: Add arm_cp15_set_exception_handler() | Sebastian Huber | 2013-05-03 | 1 | -0/+6 |
* | bsps/arm: Add arm_cp15_set_trans*_table_entries() | Sebastian Huber | 2013-05-03 | 1 | -0/+11 |
* | bsps/arm: Add arm_cp15_mmu_disable() | Sebastian Huber | 2013-05-03 | 1 | -0/+46 |
* | bsps/arm: Add arm_cp15_get_min_cache_line_size() | Sebastian Huber | 2013-05-03 | 1 | -6/+26 |
* | D-cache clean&&invalidate for Tiny6410 | Peng Fan | 2013-04-17 | 1 | -0/+21 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -6/+0 |
* | 2011-06-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-06-07 | 2 | -139/+115 |
| | | | | | * shared/include/cache_.h: Moved content of "cache.h" to "cache_.h". * shared/include/cache.h: Removed file. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 1 | -38/+38 |
| | | | | | * pxa255/pmc/pmc.c, shared/include/arm-cp15.h: Use "__asm__" instead of "asm" for improved c99-compliance. | ||||
* | Documentation. Fixed mask defines. | Thomas Doerfler | 2010-04-09 | 1 | -147/+199 |
* | Fixed _CPU_cache_disable_data() | Thomas Doerfler | 2010-03-12 | 1 | -2/+1 |
* | add support for lpc32xx | Thomas Doerfler | 2010-01-12 | 4 | -131/+818 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -4/+4 |
* | 2006-06-02 Jay Monkman | Jay Monkman | 2006-06-03 | 1 | -1/+11 |
| | | | | | | | | * at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h, s3c2400/irq/bsp_irq_init.c: Changed interrupt handling to use shared rtems_irq_connect_data struct. | ||||
* | Remove. | Ralf Corsepius | 2005-05-11 | 1 | -2/+0 |
* | Remove. | Ralf Corsepius | 2005-05-11 | 1 | -41/+0 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 1 | -1/+1 |
| | | | | | * at91rm9200/Makefile.am, mc9328mxl/Makefile.am, shared/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 1 | -2/+2 |
| | | | | | | * at91rm9200/clock/clock.c, at91rm9200/irq/irq.c, at91rm9200/pmc/pmc.c, mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h, shared/arm920/mmu.c: Remove warnings. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -14/+3 |
| | | | | | * at91rm9200/Makefile.am, mc9328mxl/Makefile.am, shared/Makefile.am: Remove build-variant support. | ||||
* | 2005-01-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -4/+0 |
| | | | | | | | * ChangeLog: Merge-in at91rm9200/ChangeLog, mc9328mxl/ChangeLog, shared/ChangeLog. * at91rm9200/ChangeLog, mc9328mxl/ChangeLog, shared/ChangeLog: Remove. | ||||
* | Reformat. | Ralf Corsepius | 2004-10-26 | 1 | -4/+2 |
* | 2004-07-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-07-24 | 1 | -0/+2 |
| | | | | | * at91rm9200/.cvsignore, mc9328mxl/.cvsignore, shared/.cvsignore: New files. | ||||
* | 2004-07-15 Jay Monkman | Jay Monkman | 2004-07-15 | 4 | -0/+330 |
* ChangeLog, Makefile.am, arm920/mmu.c, include/mmu.h: New files. |
