Update #3285.
* pxa255/include/pxa255.h: Add constants for LCD, Network, and Timer.
* pxa255/irq/bsp_irq_init.c, pxa255/irq/irq.c,
pxa255/irq/irq.h: Change to dummy_handler().
* preinstall.am, pxa255/clock/clock.c, pxa255/ffuart/ffuart.c,
pxa255/irq/bsp_irq_init.c, pxa255/timer/timer.c: Fix typos and update
timer.
* Makefile.am, configure.ac, preinstall.am: New Gumstix BSP and PXA255
support.
* pxa255/clock/clock.c, pxa255/ffuart/ffuart.c, pxa255/include/bits.h,
pxa255/include/ffuart.h, pxa255/include/pxa255.h,
pxa255/irq/bsp_irq_asm.S, pxa255/irq/bsp_irq_init.c,
pxa255/irq/irq.c, pxa255/irq/irq.h, pxa255/pmc/pmc.c,
pxa255/timer/timer.c: New files.
* at91rm9200/clock/clock.c, at91rm9200/dbgu/dbgu.c,
at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, at91rm9200/include/bits.h,
at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, at91rm9200/pmc/pmc.c,
at91rm9200/timer/timer.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/include/mc9328mxl.h, mc9328mxl/irq/bsp_irq_asm.S,
mc9328mxl/irq/bsp_irq_init.c, mc9328mxl/irq/irq.c,
mc9328mxl/irq/irq.h, mc9328mxl/timer/timer.c,
s3c2400/clock/clockdrv.c, s3c2400/timer/timer.c: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
* at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
s3c2400/irq/bsp_irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c,
dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h,
include/at91rm9200_dbgu.h, include/at91rm9200_emac.h,
include/at91rm9200_gpio.h, include/at91rm9200_mem.h,
include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
