Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt().
Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new
file <rtems/score/armv4.h> since they have nothing to do with the CPU
port.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, lpc22xx/irq/irq.c,
lpc22xx/irq/irq.h, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
pxa255/irq/irq.c, pxa255/irq/irq.h, s3c24xx/irq/irq.c,
s3c24xx/irq/irq.h: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, pxa255/clock/clock.c,
s3c24xx/clock/clockdrv.c: Include <bsp/irq.h> instead of <irq.h>.
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
s3c24xx/irq/bsp_irq_asm.S, s3c24xx/irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above.
../../../../libbsp/shared/clockdrv_shell.c.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
Remove unused vars.
mc9328mxl/clock/clockdrv.c, s3c2400/clock/clockdrv.c: Eliminate
copies of the Configuration Table. Use the RTEMS provided accessor
macros to obtain configuration fields.
*lpc22xx/irq/bsp_irq_asm.S: Add veneer for ARM<->Thumb
lpc22xx/irq/bsp_irq_init.c: add VIC address init
* lpc22xx/clock/clockdrv.c, lpc22xx/irq/irq.c, lpc22xx/irq/irq.h: Now
runs in Skyeye.
PR 1257/bsps
* at91rm9200/irq/irq.c, lpc22xx/irq/irq.c, mc9328mxl/irq/irq.c,
s3c2400/irq/irq.c: Code outside of cpukit should use the public API
for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* lpc22xx/clock/clockdrv.c, lpc22xx/include/lpc22xx.h,
lpc22xx/irq/bsp_irq_asm.S, lpc22xx/irq/bsp_irq_init.c,
lpc22xx/irq/irq.c, lpc22xx/irq/irq.h, lpc22xx/timer/timer.c: Update
BSP to address changes between 4.7 and CVS head as well as to address
comments from Ralf and Joel.
* lpc22xx/irq/bsp_irq_init.c
lpc22xx/irq/irq.c, lpc22xx/irq/irq.h: New (Initial submission).
* Makefile.am, configure.ac: Add lpc22xx support.
lpc22xx/irq/bsp_irq_asm.S, lpc22xx/timer/lpc_timer.h,
lpc22xx/timer/timer.c: New (Initial submission).
