output.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
Remove unused vars.
* lpc22xx/clock/clockdrv.c, lpc22xx/include/lpc22xx.h,
lpc22xx/irq/bsp_irq_asm.S, lpc22xx/irq/bsp_irq_init.c,
lpc22xx/irq/irq.c, lpc22xx/irq/irq.h, lpc22xx/timer/timer.c: Update
BSP to address changes between 4.7 and CVS head as well as to address
comments from Ralf and Joel.
* Makefile.am, configure.ac: Add lpc22xx support.
lpc22xx/irq/bsp_irq_asm.S, lpc22xx/timer/lpc_timer.h,
lpc22xx/timer/timer.c: New (Initial submission).
