* Makefile.am, configure.ac, preinstall.am: New Gumstix BSP and PXA255
support.
* pxa255/clock/clock.c, pxa255/ffuart/ffuart.c, pxa255/include/bits.h,
pxa255/include/ffuart.h, pxa255/include/pxa255.h,
pxa255/irq/bsp_irq_asm.S, pxa255/irq/bsp_irq_init.c,
pxa255/irq/irq.c, pxa255/irq/irq.h, pxa255/pmc/pmc.c,
pxa255/timer/timer.c: New files.
* Makefile.am, configure.ac, preinstall.am, s3c2400/include/s3c2400.h:
Add CPU type s3c2410. Add a new s3c24xx common file shared between
s3c2400 and s3c2410. Most content is moved from s3c2400 now. Some
were changed to include <s3c24xx.h> instead of <s3c2400.h>.
* s3c2410/include/s3c2410.h, s3c2410/irq/bsp_irq_asm.S,
s3c2410/irq/irq.h, s3c24xx/clock/clockdrv.c, s3c24xx/clock/support.c,
s3c24xx/include/s3c24xx.h, s3c24xx/irq/bsp_irq_init.c,
s3c24xx/irq/irq.c, s3c24xx/irq/irq.h, s3c24xx/timer/timer.c: New files.
* Makefile.am, configure.ac: Add lpc22xx support.
* lpc22xx/clock/clockdrv.c, lpc22xx/include/lpc22xx.h,
lpc22xx/irq/bsp_irq_asm.S, lpc22xx/timer/lpc_timer.h,
lpc22xx/timer/timer.c: New (Initial submission).
* configure.ac: Use RTEMS_AMPOLISH3.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Merge-in shared/Makefile.am.
* preinstall.am: New.
* shared/Makefile.am: Remove.
* Makefile.am, configure.ac: Added gp32 BSP.
* s3c2400/.cvsignore, s3c2400/Makefile.am, s3c2400/clock/clockdrv.c,
s3c2400/include/s3c2400.h, s3c2400/irq/bsp_irq_asm.S,
s3c2400/irq/bsp_irq_init.c, s3c2400/irq/irq.c, s3c2400/irq/irq.h,
s3c2400/timer/timer.c: New files.
* configure.ac: Remove RTEMS_ENABLE_BARE.
* .cvsignore, ChangeLog, Makefile.am, configure.ac: New files.
