Update #3254.
output.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
* at91rm9200/clock/clock.c, at91rm9200/dbgu/dbgu.c,
at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, at91rm9200/include/bits.h,
at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, at91rm9200/pmc/pmc.c,
at91rm9200/timer/timer.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/include/mc9328mxl.h, mc9328mxl/irq/bsp_irq_asm.S,
mc9328mxl/irq/bsp_irq_init.c, mc9328mxl/irq/irq.c,
mc9328mxl/irq/irq.h, mc9328mxl/timer/timer.c,
s3c2400/clock/clockdrv.c, s3c2400/timer/timer.c: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
* timer/timer.c: Use POSIX fixed-size types.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c,
dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h,
include/at91rm9200_dbgu.h, include/at91rm9200_emac.h,
include/at91rm9200_gpio.h, include/at91rm9200_mem.h,
include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
* console/uart.c, include/ep7312.h, startup/bspstart.c,
timer/timer.c: Convert to using c99 fixed size types.
* clock/clockdrv.c, console/uart.c, include/bsp.h, include/ep7312.h,
start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/timer.c: URL for license changed.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
