Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1832/libcpu
* at91rm9200/irq/irq.c: he bsp_interrupt_dispatch routine does not
determine the correct interrupt source number. According to the
datasheet, the reading of the interrupt vector register (AIC_IVR)
notifies the hardware that the OS is taken care of the interrupt.
Only after AIC_IVR have been read can the correct source number be
read from the interrupt status register (AIC_ISR).
* at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, lpc22xx/irq/irq.c,
lpc22xx/irq/irq.h, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
pxa255/irq/irq.c, pxa255/irq/irq.h, s3c24xx/irq/irq.c,
s3c24xx/irq/irq.h: The previous interrupt warning fix changed the
interrupt handler API. To fix this problem the generic interrupt
support framework will be used now. This eliminates a lot of copy and
paste code. The interrupt header file is now <bsp/irq.h>.
* at91rm9200/clock/clock.c, lpc22xx/clock/clockdrv.c,
mc9328mxl/clock/clockdrv.c, pxa255/clock/clock.c,
s3c24xx/clock/clockdrv.c: Include <bsp/irq.h> instead of <irq.h>.
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/bsp_irq_init.c,
mc9328mxl/irq/bsp_irq_asm.S, mc9328mxl/irq/bsp_irq_init.c,
s3c24xx/irq/bsp_irq_asm.S, s3c24xx/irq/bsp_irq_init.c: Removed files.
* Makefile.am, preinstall.am: Reflect changes above.
PR 1257/bsps
* at91rm9200/irq/irq.c, lpc22xx/irq/irq.c, mc9328mxl/irq/irq.c,
s3c2400/irq/irq.c: Code outside of cpukit should use the public API
for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* at91rm9200/clock/clock.c, at91rm9200/dbgu/dbgu.c,
at91rm9200/include/at91rm9200.h,
at91rm9200/include/at91rm9200_dbgu.h,
at91rm9200/include/at91rm9200_emac.h,
at91rm9200/include/at91rm9200_gpio.h,
at91rm9200/include/at91rm9200_mem.h,
at91rm9200/include/at91rm9200_pmc.h, at91rm9200/include/bits.h,
at91rm9200/irq/irq.c, at91rm9200/irq/irq.h, at91rm9200/pmc/pmc.c,
at91rm9200/timer/timer.c, mc9328mxl/clock/clockdrv.c,
mc9328mxl/include/mc9328mxl.h, mc9328mxl/irq/bsp_irq_asm.S,
mc9328mxl/irq/bsp_irq_init.c, mc9328mxl/irq/irq.c,
mc9328mxl/irq/irq.h, mc9328mxl/timer/timer.c,
s3c2400/clock/clockdrv.c, s3c2400/timer/timer.c: Correct license URL
and/or fix mistake in copyright notice. Both of these mistakes appear
to be from code submitted after these changes were made previously.
* at91rm9200/irq/bsp_irq_init.c, mc9328mxl/clock/clockdrv.c,
s3c2400/irq/bsp_irq_init.c: Changed interrupt handling
to use shared rtems_irq_connect_data struct.
PR 776/bsps
* at91rm9200/irq/bsp_irq_asm.S, at91rm9200/irq/irq.h: Added code to
pass interrupt vector number to ISR on AT91RM9200
* at91rm9200/irq/irq.h, mc9328mxl/irq/irq.h, s3c2400/irq/irq.h:
Modified names and types to match rtems/irq.h. Note: rtems/irq.h
should be included after the addition of a parameter to ISRs.
* at91rm9200/clock/clock.c, at91rm9200/irq/irq.c, at91rm9200/pmc/pmc.c,
mc9328mxl/clock/clockdrv.c, mc9328mxl/irq/irq.c, mc9328mxl/irq/irq.h,
shared/arm920/mmu.c: Remove warnings.
* ChangeLog, Makefile.am, clock/.cvsignore, clock/clock.c,
dbgu/.cvsignore, dbgu/dbgu.c, include/at91rm9200.h,
include/at91rm9200_dbgu.h, include/at91rm9200_emac.h,
include/at91rm9200_gpio.h, include/at91rm9200_mem.h,
include/at91rm9200_pmc.h, include/bits.h, irq/.cvsignore,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
pmc/pmc.c, timer/.cvsignore, timer/timer.c: New files.
