* ChangeLog: Corrected comment.
* clock/ckinit.c: Removed commented out include of bsp.h.
* clock/ckinit.c: Removed include of <bsp.h>. Also switch to
macros to get configuration data.
* timer/timer.c: Removed include of <bsp.h>. Fixed comment
that said 4650 (a mips part).
* clock/clock.S: Commented out non-GNU assembly.
* clock/Makefile.am, timer/Makefile.am: Include compile.am
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
