2003-02-14 | 2003-02-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -7/+0 | |
AMD a29k is obsolete. * Makefile.am: Removed reference. * a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/configure.ac, a29k/clock/.cvsignore, a29k/clock/Makefile.am, a29k/clock/ckinit.c, a29k/clock/clock.S, a29k/clock/clock.h, a29k/timer/.cvsignore, a29k/timer/Makefile.am, a29k/timer/timer.c, a29k/timer/timerisr.c: Removed. | |||||
2000-01-31 | Patch rtems-rc-20000118-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+3 | |
that contains: * cleanups to configuration files * A reworked gccnewlib.spec.in: I have reformated it for enhanced readability and added more rtems-base packages. It now should be free of any installation conflicts (If there still remain some, they should be regarded as bugs). * A fix to the bin2boot RTEMS_BSP issue (make RTEMS_BSP="pc386 pc486" now works). * removes libbsp/bare/wrapup * Further cleanups | |||||
2000-01-26 | Patch rtems-rc-20000118-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
that converts the a29k to automake. This patch contains * An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS, most code inside them seems to be empty stubs. One file even contains a function called mips_*** which might indicate that this part might contain mips code or the code the initial porter used as template for porting. Unfortunately, I don't know anything about the a29k so I can't comment on the details. * A dummy bsp_specs to libbsp/29k/portsw * An update to the automake files related to the a29k. Note: * This patch is completely untested, because I don't have a toolchain for it. * The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue hits again. |
