PR 1986/libcpu
* shared/src/cache_aligned_malloc.c:
Include <rtems/rtems/cache.h>.
* Makefile.am: Remove reference to non-existing file
shared/include/utility.h.
* shared/include/cache.h, shared/src/cache_manager.c: Removed include
files to reduce implementation constraints.
* shared/src/no_cache.c: New file.
shared/include/powerpc-utility.h: Use constraint "b" for address
base registers in inline assembler statements.
Update for status-checks.h changes.
* Makefile.am: Don't install files from shared/.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* nios2/Makefile.am, nios2/configure.ac, nios2/preinstall.am,
nios2/shared/cache/cache.c, nios2/shared/cache/cache_.h,
nios2/shared/misc/memcpy.c: New files.
* README: i960 obsoleted.
* i960/.cvsignore, i960/ChangeLog, i960/Makefile.am, i960/configure.ac,
i960/i960ca/.cvsignore, i960/i960ca/Makefile.am,
i960/i960ca/cpu_install_intr_stack.c,
i960/i960ca/cpu_install_raw_isr.c, i960/i960ka/.cvsignore,
i960/i960ka/Makefile.am, i960/i960ka/cpu_install_intr_stack.c,
i960/i960ka/cpu_install_raw_isr.c, i960/i960rp/.cvsignore,
i960/i960rp/Makefile.am, i960/i960rp/cpu_install_intr_stack.c,
i960/i960rp/cpu_install_raw_isr.c, i960/include/i960CA.h,
i960/include/i960HA.h, i960/include/i960JX_RP_common.h,
i960/include/i960KA.h, i960/include/i960RP.h: Removed.
* mips64orion/.cvsignore, mips64orion/ChangeLog,
mips64orion/Makefile.am, mips64orion/configure.ac,
mips64orion/clock/.cvsignore, mips64orion/clock/Makefile.am,
mips64orion/clock/ckinit.c, mips64orion/clock/clock.S,
mips64orion/clock/clock.h, mips64orion/timer/.cvsignore,
mips64orion/timer/Makefile.am, mips64orion/timer/gettime.S,
mips64orion/timer/timer.c: Removed.
* Makefile.am: Reformat.
* hppa1.1/.cvsignore, hppa1.1/ChangeLog, hppa1.1/Makefile.am,
hppa1.1/configure.ac, hppa1.1/clock/.cvsignore,
hppa1.1/clock/Makefile.am, hppa1.1/clock/clock.c,
hppa1.1/include/.cvsignore, hppa1.1/include/Makefile.am,
hppa1.1/include/runway.h, hppa1.1/include/semaphore.h,
hppa1.1/milli/.cvsignore, hppa1.1/milli/Makefile.am,
hppa1.1/milli/milli.S, hppa1.1/semaphore/.cvsignore,
hppa1.1/semaphore/Makefile.am, hppa1.1/semaphore/semaphore.c,
hppa1.1/timer/.cvsignore, hppa1.1/timer/Makefile.am,
hppa1.1/timer/timer.c: Removed.
* shared/include/cache.h, shared/src/cache_aligned_malloc.c,
shared/src/cache_manager.c: URL for license changed.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
AMD a29k is obsolete.
* Makefile.am: Removed reference.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/configure.ac,
a29k/clock/.cvsignore, a29k/clock/Makefile.am, a29k/clock/ckinit.c,
a29k/clock/clock.S, a29k/clock/clock.h, a29k/timer/.cvsignore,
a29k/timer/Makefile.am, a29k/timer/timer.c, a29k/timer/timerisr.c:
Removed.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.in: Remove.
* Makefile.am: reformat noinst_HEADERS to work around a bug in
automake-1.4-p5.
* configure.in: autoupdate to autoconf-2.52, apply RTEMS_CPU_SUBDIRS.
* shared/src/cache_aligned_malloc.c: Added include of <stdlib.h>
to eliminate warnings.
* shared/src/cache_manager.c
(rtems_cache_invalidate_multiple_instruction_lines): If
CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is
an instruction cache but no notion of line size.
* shared/include/cache.h: Improved file header.
* shared/src/cache_manager.c: Minor bug fix -- changed > to >= so the
last address is invalidated.
* shared/src/cache_manager.c (rtems_cache_flush_multiple_data_lines,
rtems_cache_invalidate_multiple_data_lines): Do not operate on the
entire address space when flushing zero bytes.
