* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -0/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | ||||
* | Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along | Joel Sherrill | 1998-10-28 | 3 | -4/+6 |
| | | | | with libchip. | ||||
* | Updates to tree to make it build with all desired changes and the conversion | Joel Sherrill | 1998-09-11 | 3 | -6/+6 |
| | | | | of the SONIC driver to the new FreeBSD stack instead of KA9Q. | ||||
* | Don't disable the RX/TX on close in polled mode. | Joel Sherrill | 1998-08-13 | 1 | -2/+3 |
| | | | | Fixed a comment. | ||||
* | Commented out the code which yields the CPU when the serial controller is | Joel Sherrill | 1998-08-05 | 3 | -0/+6 |
| | | | | | busy. This type of behavior perturbs the tests and many of them will not pass. | ||||
* | New files. | Joel Sherrill | 1998-07-30 | 2 | -0/+11 |
* | Corrected spacing. | Joel Sherrill | 1998-07-28 | 2 | -14/+6 |
* | Added comments and corrected spacing. | Joel Sherrill | 1998-07-25 | 2 | -21/+28 |
* | Corrected spacing and added headers. | Joel Sherrill | 1998-07-25 | 1 | -17/+28 |
* | Added ns16550_set_attributes. | Joel Sherrill | 1998-07-25 | 2 | -4/+105 |
* | Corrected spacing and added a comment. | Joel Sherrill | 1998-07-25 | 1 | -3/+5 |
* | Updated to reflect set attributes. | Joel Sherrill | 1998-07-25 | 1 | -2/+9 |
* | Rewrote NS16550 TX interrupt processing to use termios for the buffer | Joel Sherrill | 1998-07-25 | 3 | -125/+84 |
| | | | | | and manage the interrupt sources like the other drivers. This let use remove the ns16550_flush() routine. | ||||
* | Removed TX ring buffer. | Joel Sherrill | 1998-07-25 | 1 | -2/+0 |
* | Changed variable to hold received data to unsigned. | Joel Sherrill | 1998-07-25 | 2 | -2/+2 |
* | Added constants for z85c30_enable_interrupts. | Joel Sherrill | 1998-07-25 | 1 | -6/+17 |
* | Removed z85c30_flush(). | Joel Sherrill | 1998-07-25 | 1 | -124/+79 |
| | | | | | | Reworked transmit interrupt processing to remove ring buffer and to mask the TX empty interrupt when it was not expected. This code now uses termios to buffer TX output. | ||||
* | Changed comment on TxBuffer. | Joel Sherrill | 1998-07-25 | 1 | -1/+2 |
* | Removed mc68681_flush and corrected spacing. | Joel Sherrill | 1998-07-25 | 2 | -33/+5 |
* | Added information on Chris Johns' suggestion to use pointers internally | Joel Sherrill | 1998-07-25 | 1 | -0/+3 |
| | | | | rather than doing repeated table lookups. | ||||
* | New file. | Joel Sherrill | 1998-07-25 | 1 | -0/+49 |
* | Changed to utilize return status from rtems_termios_dequeue_characters() | Joel Sherrill | 1998-07-25 | 1 | -4/+9 |
| | | | | and to correctly set the TX active indicator. | ||||
* | Interrupts were incorrectly managed with a disable/disable pair rather | Joel Sherrill | 1998-07-25 | 1 | -2/+2 |
| | | | | than with a disable/enable pair. | ||||
* | Removed use of data port for z8530. | Joel Sherrill | 1998-07-18 | 2 | -90/+54 |
| | | | | Move some code around. | ||||
* | Corrected header files. | Joel Sherrill | 1998-07-16 | 1 | -1/+2 |
* | Minor corrections for typos to get it to compile. | Joel Sherrill | 1998-07-16 | 1 | -2/+2 |
* | Split default baud rate table into its own file. This shrinks the | Joel Sherrill | 1998-07-16 | 5 | -108/+124 |
| | | | | | | size of the minimum mc68681 driver. The clock speed field can not now be configured as NULL but must instead specify the address of the default table. | ||||
* | Fixed typos. | Joel Sherrill | 1998-07-15 | 4 | -4/+7 |
* | Added default z85c30 register access routines. | Joel Sherrill | 1998-07-15 | 3 | -1/+129 |
* | Added default mc68681 register access routines. | Joel Sherrill | 1998-07-15 | 5 | -12/+142 |
* | Added check for proper deviceType to interrupt processing code. | Joel Sherrill | 1998-07-15 | 2 | -2/+4 |
* | Added interrupt mask and interrupt status register bit constants. | Joel Sherrill | 1998-07-15 | 1 | -1/+24 |
| | | | | | Added prototype for mc68681_build_imr(), mc68681_process(), and mc68681_enable_interrupts(). | ||||
* | Added default mc68681 register access routines. | Joel Sherrill | 1998-07-15 | 1 | -0/+49 |
* | Switched from driver's own buffering to using termios. This eliminated | Joel Sherrill | 1998-07-15 | 1 | -121/+93 |
| | | | | | | | | | | | | | | | | | | the need for the ringbuffer manipulation in this driver. It should also allow the removal of mc68681_flush. This greatly simplified the interrupt processing. Reworked Interrupt Mask Register handling. Added imr field to the device context. This handling makes sure that the IMR accurately reflects the state of the port in use and its mate. This required the reworking of the mc68681_enable_interrupts() routine to allow for the specification of which interrupt sources were being enabled/disabled. Reworked initialization to reset using port address rather than chip base address. Basically we were always resetting port 0. Added deviceType field which allows for multiple chips of the same class to have the same vector number. | ||||
* | Added information on the deviceType field. | Joel Sherrill | 1998-07-15 | 2 | -0/+8 |
* | Added default mc68681 register access routines. | Joel Sherrill | 1998-07-15 | 1 | -1/+2 |
* | Added comment to remove use of TxBuffer ring buffer in all libchip drivers. | Joel Sherrill | 1998-07-15 | 1 | -1/+14 |
| | | | | The scheme used in the mc68681 is the one to follow. | ||||
* | Switched deviceOutputUsesInterrupts to TRUE so output would be interrupt | Joel Sherrill | 1998-07-15 | 1 | -148/+147 |
| | | | | | | | | | | | | | | | driven. Redid "mate determination" code to check that the chip base address was the same but the port address was different. Moved mc68681_process and mc68681_build_imr to the bottom of the file so they would not be inlined. Removed the code which forced mc68681_build_imr to always return 0 which resulted in interrupts never being enabled from the chip. Corrected spacing in prototype of mc68681_write_support_int. | ||||
* | Switched to "deviceOutput = TRUE" which made device output use interrupts. | Joel Sherrill | 1998-07-15 | 1 | -1/+1 |
* | Added set attributes routine but did not hook it in to the table. | Joel Sherrill | 1998-07-09 | 2 | -13/+110 |
| | | | | Switched to shared default probe. | ||||
* | Added new files. | Joel Sherrill | 1998-07-09 | 1 | -1/+3 |
* | Renamed so we could have one file per routine. | Joel Sherrill | 1998-07-09 | 1 | -37/+0 |
* | Switched to shared default probe routine. | Joel Sherrill | 1998-07-09 | 1 | -14/+3 |
* | Switched to default probe routine. | Joel Sherrill | 1998-07-09 | 1 | -17/+2 |
* | Added new baud rate to number function and default serial probe routine. | Joel Sherrill | 1998-07-09 | 4 | -0/+107 |
| | | | | | Renamed sersupp.c so we could have one routine per file to decrease the baggage pulled into an application by default. | ||||
* | Added proper handling of extended baud rate table selection at boot time. | Joel Sherrill | 1998-07-09 | 1 | -1/+6 |
| | | | | Still need to address default terminal settings. | ||||
* | Properly handle extended baud rate set commands. | Joel Sherrill | 1998-07-09 | 1 | -15/+22 |
| | | | | | | | | | | | | | Temporarily "if 0" of code which enables interrupts. Moved setting of command registers at open but the current implementation is questionable. Added reset of RX errors while polling TX. Read polled character as unsigned. Baud rate mask must be in upper and lower nibble. | ||||
* | Corrected definition of MC68681_RX_BUFFER. | Joel Sherrill | 1998-07-09 | 1 | -1/+1 |
* | Changed static to MC68681_STATIC to make all data and routines | Joel Sherrill | 1998-07-09 | 1 | -105/+192 |
| | | | | | | | | | globally visiable to ease debugging. Added support for mc68681 "2 column" style baud rate table as well as the Exar 88681 "4 column" style baud rate table. Added support for user override of the default baud rate table. | ||||
* | Removed commented out line. | Joel Sherrill | 1998-07-09 | 1 | -1/+0 |
