* | Increased block size to 128 and added comments based on feedback from | Joel Sherrill | 2000-02-11 | 1 | -1/+13 | |
| | | | | Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>. | |||||
* | Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-02-08 | 1 | -2/+0 | |
| | | | | | | | | | | | | | | | | | that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling) | |||||
* | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 2000-01-31 | 1 | -1/+0 | |
| | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | |||||
* | Spacing corrected. | Joel Sherrill | 2000-01-05 | 1 | -1/+1 | |
* | Removed warnings. | Joel Sherrill | 1999-12-13 | 1 | -1/+1 | |
* | Warning removal patch from Philip A. Prindeville <philipp@zembu.com>. | Joel Sherrill | 1999-12-13 | 1 | -1/+1 | |
* | Added RTEMS_IO_ERROR. | Joel Sherrill | 1999-12-13 | 1 | -0/+1 | |
* | Removed duplicate definition of rtems_filesystem_umask. | Joel Sherrill | 1999-11-30 | 1 | -6/+0 | |
* | Corrected so they would compile with POSIX disabled. | Joel Sherrill | 1999-11-30 | 2 | -2/+3 | |
* | Fixed spacing. | Joel Sherrill | 1999-11-29 | 1 | -1/+1 | |
* | Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-22 | 2 | -126/+127 | |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | |||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 104 | -208/+104 | |
* | Added TERMINAL_IDENTIFICATION pieces. | Joel Sherrill | 1999-11-16 | 1 | -3/+4 | |
* | Fixed bug. | Jennifer Averett | 1999-11-16 | 1 | -3/+3 | |
* | Added handler for fsync. For the memfile it is the same as the data sync. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 | |
* | Works now. | Joel Sherrill | 1999-11-16 | 1 | -19/+12 | |
| | | | | | Removed times() since the version in the C Library support code is fine. | |||||
* | New file. | Joel Sherrill | 1999-11-16 | 1 | -0/+113 | |
* | Added. | Joel Sherrill | 1999-11-16 | 6 | -3/+209 | |
* | Source and destination arguments to strncpy were swapped. This mistake | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
| | | | | was made in the conversion of bcopy() to strncpy(). | |||||
* | Added imfs_unixstub.c to satisfy linker problems on UNIX port. | Joel Sherrill | 1999-11-09 | 2 | -1/+73 | |
* | Correctly set and called handlers table for the link. | Jennifer Averett | 1999-11-05 | 1 | -1/+3 | |
* | Fixed comment | Jennifer Averett | 1999-11-05 | 1 | -1/+1 | |
* | Moved imfs set handlers prototype to the imfs.h file. | Jennifer Averett | 1999-11-05 | 2 | -6/+4 | |
* | New file. | Joel Sherrill | 1999-11-05 | 1 | -0/+38 | |
* | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1999-11-05 | 8 | -65/+105 | |
| | | | | and not handling every case properly. | |||||
* | Following comments from Eric Norum <eric@cls.usask.ca>, a fairly | Joel Sherrill | 1999-11-05 | 4 | -287/+262 | |
| | | | | | | | substantial upgrade of newlibc.c occurred. Now the user extension data area is used rather than notepads and as many routines as possible were split into other files further reducing the minimum footprint of an RTEMS executable. | |||||
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 1 | -2/+1 | |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | |||||
* | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1999-11-02 | 11 | -129/+228 | |
| | | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | |||||
* | Fixed F_SETFL to properly convert between internal | Joel Sherrill | 1999-11-02 | 1 | -2/+3 | |
| | | | | libio flags and external fcntl.h style flags. | |||||
* | Added support for configuring base filesystem. First attempt at | Joel Sherrill | 1999-11-02 | 1 | -17/+41 | |
| | | | | | | a full mount table at initialization. This is the wrong place to mount filesystems 2-n since no device drivers are initialized yet. | |||||
* | Install imfs.h so base filesystem can be configured or IMFS mounted | Joel Sherrill | 1999-11-02 | 1 | -1/+1 | |
| | | | | by an application. | |||||
* | Check for NULL being passed in. | Joel Sherrill | 1999-11-02 | 4 | -2/+17 | |
* | Fixed typo where memfile_handlers set twice and directory_handlers | Joel Sherrill | 1999-11-02 | 1 | -3/+3 | |
| | | | | was not set. | |||||
* | Properly initialize location variable. | Joel Sherrill | 1999-11-02 | 1 | -0/+8 | |
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 6 | -11/+21 | |
* | Joel added a table of mount entry requests to be processed during | Jennifer Averett | 1999-10-29 | 1 | -0/+14 | |
| | | | | initialization. | |||||
* | New files created by split of old imfs_handlers.c. | Joel Sherrill | 1999-10-26 | 3 | -0/+111 | |
* | Added include of libio.h so this would compile when posix is disabled. | Joel Sherrill | 1999-10-26 | 1 | -0/+1 | |
* | Added initial cut at miniIMFS which leaves out memfile and directory | Joel Sherrill | 1999-10-26 | 12 | -333/+232 | |
| | | | | | readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level. | |||||
* | Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 1 | -7/+8 | |
| | | | | <raguet@crf.canon.fr> to use a local variable. | |||||
* | Added code to correctly free any allocated space during the evaluation | Jennifer Averett | 1999-10-25 | 2 | -72/+74 | |
| | | | | process. | |||||
* | Changed leading spaces to periods to ease comparing test output. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 | |
* | Spacing. | Joel Sherrill | 1999-10-12 | 1 | -0/+1 | |
* | Split null handlers table to own file and renamed. | Joel Sherrill | 1999-10-12 | 7 | -77/+17 | |
| | | | | Renamed IMFS handler tables to include IMFS prefix. | |||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 16 | -92/+57 | |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | |||||
* | Fixed spacing. | Joel Sherrill | 1999-10-12 | 1 | -1/+1 | |
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 5 | -31/+144 | |
| | | | | routine imfs_fcntl.c | |||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 15 | -68/+227 | |
| | | | | node used to manage file access. | |||||
* | Changed bcopy to strncpy to stick to ANSI/ISO routines. | Joel Sherrill | 1999-10-12 | 1 | -1/+1 | |
* | Moved RTEMS error and association from libmisc to libc support to | Joel Sherrill | 1999-10-11 | 1 | -3/+9 | |
| | | | | | avoid cyclic dependencies generated when moving packages to the top level. |
