be resolved.
and gcc 2.8.x -specs options.
should simplify the build process.
makes gnat pass about 55 more tests in the acvc.
statuses being returned to gnat runtime in order for it to raise
use_errors. This was needed to identify the places in gnat's runtime
which needed to be addressed.
malloc for per-thread reentrancy structure allocation.
miscellaneous corrections in casting.
mode have stubs.
This implementation of sleep is now only used when the POSIX API is not
configured.
applications which use only the rtems api (i.e. not the posix api) will
link.
of the POSIX API necessary to support the GNAT runtime to initially compile.
We now have verified that the specifications for the necessary routines
are correct per the POSIX standards we have.
from the application code, this file required more visibility than
is given by default to application code.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
insures that stdout is line buffered (see setvbuf).
now pretend that everything is a tty. This insures that newlib makes
the console output line buffered.
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
correct Information block.
+ variable length messages
+ named devices
+ debug monitor
newlib C library.
Fixed bug where length did not take into account amount added
for alignment requirements.
newlib C library.
+ c/src/lib/libc/support/generic/malloc.c did not initialize the
sbrk amount
+ _Thread_Handler in c/src/exec/rtems/thread.c left a window
during the begin extension which could result in a context switch
fixed places which did not correctly distinguish between an
CPU_isr and a CPU_isr_entry.
