path: root/c/src/lib/libc/tcsetattr.c (follow)
* Added local prototype of ioctl() to avoid requiring sys/ioctl.h.Joel Sherrill1999-06-111-1/+3
* Use proper include for libio.h.Joel Sherrill1999-03-161-1/+1
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+38
