POSIX API.
These were noticed by Eric Norum.
a result of enabling the newlib POSIX directory.
I've gone through and cleaned up the TFTP driver so that it fits
into the libio system. Here's the comment from the new driver:
* Usage:
* To open `/bootfiles/image' on `hostname' for reading:
* fd = open ("/TFTP/hostname/bootfiles/image", O_RDONLY);
* The `hostname' can be a symbolic name or four
* dot-separated decimal values.
* To open a file on the host which supplied the BOOTP
* information just leave the `hostname' part empty:
* fd = open ("/TFTP//bootfiles/image", O_RDONLY);
You can `fopen' TFTP files the same way:
fp = fopen (fullname, "r");
nread = fread (cbuf, sizeof cbuf[0], sizeof cbuf, fp);
The diff's are included below. I've also modified the TFTP demo
program and the bootstrap PROM example. They should be on my ftp
site `soon'.
The one thing I don't like is the way I had to do an end-run on the
libio routines to get errno passed back from my driver to the
application (since there are some errno codes that don't map to RTEMS
status codes). My approach was to set errno in the driver and have
the driver routine return an RTEMS status code that I `know' isn't in
the errno_assoc[] in libio.c.
Perhaps there should be an RTEMS_TRANPARENT_ERRNO status code (or
something similar) which driver routines could return to indicate
that the driver routine has set errno and that the libio routines
shouldn't attempt to map the returned status code to errno.
Actually, I think the entire I/O system needs looking at -- as
you've already mentioned. The hacks I've dropped in to syscalls.c to
make fstat work, for example, are *not* shining examples of good
code......
With this in place, it is possible to fdopen a TCP stream socket and
getc/fprintf/etc. on the STDIO stream!
should simplify the build process.
makes gnat pass about 55 more tests in the acvc.
statuses being returned to gnat runtime in order for it to raise
use_errors. This was needed to identify the places in gnat's runtime
which needed to be addressed.
now pretend that everything is a tty. This insures that newlib makes
the console output line buffered.
+ variable length messages
+ named devices
+ debug monitor
