path: root/c/src/lib/libc/stat.c (follow)
* Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1999-10-121-4/+2
| | | | | places to make sure memory allocated for filesystem specifif nodes gets freed.
* Added call to freenod to let each filesystem free its own internalJoel Sherrill1999-10-121-2/+10
| | | | node used to manage file access.
* Added lstat().Joel Sherrill1999-04-221-6/+20
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+79
