path: root/c/src/lib/libc/seekdir.c (unfollow)
2001-01-082001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+4
* configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-11-02Check for NULL being passed in.Joel Sherrill1-1/+5
1999-01-04Removed blank linesJoel Sherrill1-1/+0
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-5/+22
1998-10-22Changed all of these to stubs.Joel Sherrill1-19/+4
1998-10-13New files.Joel Sherrill1-12/+17
1998-05-11new file to support execv family support in newlibJoel Sherrill1-12/+13
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1995-07-12Ada95, gnat, go32Joel Sherrill1-4/+5
