path: root/c/src/lib/libc/scandir.c (unfollow)
1999-11-16Source and destination arguments to strncpy were swapped. This mistakeJoel Sherrill1-1/+1
was made in the conversion of bcopy() to strncpy().
1999-10-12Changed bcopy to strncpy to stick to ANSI/ISO routines.Joel Sherrill1-1/+1
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-11/+137
1998-10-22Changed all of these to stubs.Joel Sherrill1-137/+10
1998-10-13New files.Joel Sherrill1-0/+150
