path: root/c/src/lib/libc/no_libc.c (unfollow)
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-9/+11
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1997-01-29Modifications to make go32 build using new i386-go32-rtems toolsetJoel Sherrill1-1/+1
and gcc 2.8.x -specs options.
1996-09-18dummy function added to satisfy ANSIJoel Sherrill1-0/+10
1996-01-15updates from Tony Bennett for PA and UNIX portsJoel Sherrill1-1/+1
