and gcc 2.8.x -specs options.
should simplify the build process.
malloc for per-thread reentrancy structure allocation.
mode have stubs.
This implementation of sleep is now only used when the POSIX API is not
configured.
applications which use only the rtems api (i.e. not the posix api) will
link.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
insures that stdout is line buffered (see setvbuf).
Changed back to Newlib for Solaris UNIX simulator.
like signal dispatching.
