1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1999-11-02 | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1 | -1/+0 | |
should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | |||||
1999-10-26 | Added initial cut at miniIMFS which leaves out memfile and directory | Joel Sherrill | 1 | -0/+71 | |
readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level. |
