configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
PROBLEMS
can/will be fixed.
The reentrant versions of the malloc functions in
c/src/lib/libc/malloc.c
do not match the definitions in newlib. These will be used if you use
newlib routines such as fdopen. I believe this patch to malloc.c is
needed to provide the correct versions.
RTEMS workspace is to be zeroed out.
should simplify the build process.
miscellaneous corrections in casting.
newlib C library.
Fixed bug where length did not take into account amount added
for alignment requirements.
+ c/src/lib/libc/support/generic/malloc.c did not initialize the
sbrk amount
+ _Thread_Handler in c/src/exec/rtems/thread.c left a window
during the begin extension which could result in a context switch
fixed places which did not correctly distinguish between an
CPU_isr and a CPU_isr_entry.
