* | 2000-09-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-28 | 1 | -4/+4 |
| | | | | | | | | | | | | | | | * libc/libio.h (rtems_filesystem_file_handlers_r, rtems_filesystem_operations_table): Added _h to all structure fields to indicate they are "handlers". * libc/libio_.h, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/imfs_eval.c, libc/imfs_unlink.c, libc/ioctl.c, libc/ioman.c, libc/link.c, libc/lseek.c, libc/mknod.c, libc/mount.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: Modified to reflect above name change. | ||||
* | 2000-08-11 Chris Johns <ccj@acm.org> | Joel Sherrill | 2000-08-11 | 1 | -0/+8 |
| | | | | | | | | | | | | | | | * libc/chmod.c: Return ENOTSUP if filesystem does not have handler. * libc/eval.c: Ditto. * libc/fcntl.c: Ditto. * libc/fsync.c: Ditto. * libc/ioctl.c: Ditto. * libc/ioman.c: Ditto. * libc/link.c: Ditto. * libc/memfile.c: Ditto. * libc/mknod.c: Ditto. * libc/symlink.c: Ditto. * libc/libio.h(rtems_filesystem_dev_major_t): New macro. * libc/libio.h(rtems_filesystem_dev_minor_t): New macro. | ||||
* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 1 | -20/+7 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 1 | -5/+32 |
| | | | | node used to manage file access. | ||||
* | Added reentrant versions. | Joel Sherrill | 1999-04-15 | 1 | -0/+21 |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -0/+60 |
overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. |
