path: root/c/src/lib/libc/ioctl.c (unfollow)
1999-01-20More general fix based on bug report and patch from Ian Lance TaylorJoel Sherrill1-0/+1
<ian@airs.com> to fix this problem: There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It does not check whether the file descriptor it is passed is open. This can cause it to make a null dereference if it is passed a file descriptor which is in the valid range but which was not opened, or which was already closed.
1998-12-10Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1-5/+6
all conflicts.
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-0/+57
