path: root/c/src/lib/libc/imfs_link.c (unfollow)
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-02-24Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill1-1/+1
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-0/+72
