path: root/c/src/lib/libc/imfs_getchild.c (follow)
* Removed asserts that shouldn't be called and commented case where thisJennifer Averett1999-03-311-1/+2
| | | | indicates an internal error.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+68
