path: root/c/src/lib/libc/imfs_eval.c (follow)
* Corrected spacing and added some new error checks that were neededJoel Sherrill1999-02-051-9/+9
| | | | to avoid dereferencing NULLs.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+638
