path: root/c/src/lib/libc/imfs_directory.c (unfollow)
1999-11-02The object memfile.o was being included in the miniIMFS even though itJoel Sherrill1-0/+76
should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
1999-06-14Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>.Joel Sherrill1-6/+0
1999-05-27Removed usage of printf.Joel Sherrill1-1/+1
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-0/+278
