path: root/c/src/lib/libc/imfs_directory.c (follow)
* The object memfile.o was being included in the miniIMFS even though itJoel Sherrill1999-11-021-0/+76
| | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
* Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>.Joel Sherrill1999-06-141-6/+0
* Removed usage of printf.Joel Sherrill1999-05-271-1/+1
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+278
