<ian@airs.com> to fix this problem:
There is a small bug in __rtems_close in c/src/lib/libc/libio.c. It
does not check whether the file descriptor it is passed is open. This
can cause it to make a null dereference if it is passed a file
descriptor which is in the valid range but which was not opened, or
which was already closed.
all conflicts.
PROBLEMS
can/will be fixed.
